Aligning and distributing objects
Command
Path
Shortcut
Align/Distribute
Modify > Align
Context menu
Ctrl+= (Windows)
Cmd+= (Mac)
The Align/Distribute command aligns and distributes multiple objects based upon the vertical and horizontal axes, relative to the screen.
To align/distribute objects:
Select the objects to be aligned/distributed.
Select the command.
Alternatively, right-click on the object to serve as the alignment reference. The alignment reference is locked into place, and the other selected objects are aligned relative to it. Select Align/Distribute from the context menu. The most common align and distribute commands display on a flyout context menu. Select the desired command, or select Align/Distribute to open the Align/Distribute Objects dialog box.
The Align/Distribute Objects dialog box opens.
Select the alignment/distribution criteria. Objects are only moved along the horizontal and vertical axes.
Parameter
Description
Align
Aligns objects along the horizontal or vertical axis
Distribute
Distributes objects along the horizontal or vertical axis
Horizontal
Left
Align/distribute by the left side of the selected objects
Center
Align/distribute by the centers of the selected objects
Insertion Point
Align/distribute by the insertion points of the selected plug-in objects and/or symbols.
If the selection contains objects without insertion points, they are aligned by their geometric centers.
Right
Align/distribute by the right side of the selected objects
Spacing
Distribute the spacing equally between the left and right sides of adjacent objects
Vertical
Top
Align/distribute by the top of the selected objects
Center
Insertion Point
Bottom
Align/distribute by the bottom of the selected objects
Spacing
Distribute the spacing equally between tops and bottoms of adjacent objects
The program aligns/distributes the selected objects.
Loci and locked objects are special objects and behave differently when present during an alignment/distribution operation.
If a locus point is one of the selected objects, all objects are aligned relative to that locus. If there are multiple loci in the selection, then the loci are aligned/distributed like any other object.
Locked objects in a selection do not move. Other objects are aligned/distributed relative to the locked objects.
Aligning and distributing objects in 3D
Aligning objects to grid
Aligning and distributing leader lines
